McCormick 22 sickle bar
shawn
06-10-2004 18:31:30
I have a McCormick 22 sickle bar that I run on my international 140. every time i lift the bar up the sickle falls out. I think i am missing a retaining block on the end. Does any one know what it is called and where I can find one. Thanks; Shawn
Hugh MacKay
06-10-2004 19:15:39
 Re: McCormick 22 sickle bar in reply to shawn, 06-10-2004 18:31:30
Shawn: You could be missing one of two items; number 1 a small turned up piece of metal on end of hold down plate could be broken off. These are quite easily fabricated by welding a piece of metal where it broke off. This is at 90 degrees to plate.
The second item is the 1-1/4" stem protruding from side of pitman clamp and catches on the first piece I mentioned, and could be broke off. Not sure how successful you will be at welding this back on.
In either case you should be able to see the break where it broke from. Another thing you can do is put a light chain under pitman arm near the end, and loose enough so it doesn't interfere with operation yet holds cutter from droping when in upright position. The chain or other subsitute will also hold the pitman arm in place should you be using tractor for other jobs without a cutter in place.
Leroy
06-11-2004 06:25:04
 Re: Re: McCormick 22 sickle bar in reply to Hugh MacKay, 06-10-2004 19:15:39
Could also just be the pitman just turned over so that pin is on wrong side, I have seen this
Hugh MacKay again
06-12-2004 03:35:02
 Re: Re: Re: McCormick 22 sickle bar in reply to Leroy, 06-11-2004 06:25:04
Leroy: While I said I had never seen this, thinking about it my guess is it would be next to impossible to couple pitman to the cutter with the pitman up side down, at least on an IH mower.
Leroy
06-13-2004 08:30:44
 Re: Re: Re: Re: McCormick 22 sickle bar in reply to Hugh MacKay again, 06-12-2004 03:35:02
The one I seen it on was a New Idea, and it would be possible an any of the mowers I have setting here, IHC horse and tractor, MM, Ford, Ferguson, Oliver, NI, verry easy done, complet pitman turned upside down or just the clamp bolted upside down
Hugh MacKay
06-11-2004 12:28:49
Leroy: Good point, that is one I hadn't run across.
steveormary
06-11-2004 13:53:10
 Re: Re: Re: Re: McCormick 22 sickle bar in reply to Hugh MacKay, 06-11-2004 12:28:49
And keep your fingers out from between the guards.
