Round balers
mike strong
06-10-2004 18:25:05
Hi All. New to round baling. I bought a vermeer 504G. I have 2 questions. 1) the pickup stopped turning. Turns some and stops. I just greased everything - maybe something that shouldn't have been? The weighted stopper had gotten stuck. Pully turns but like I said it stops. Any ideas?
2) why didn't they put high spots on the rollers so the belts stay centered on position? If they designed them this way you wouldn't need the guides and they would not rub the belts. Are all round balers this way?
Wade Burt
06-11-2004 08:43:15
 Re: Round balers in reply to mike strong, 06-10-2004 18:25:05
I have 2 605 H Vermeer Balers. When the bale gets to a certian size in the chamber my pickup reel will stop turning. The baler part keeps turning. I would suggest that you refer to the operators manuel. I didn't have one until I bought the second baler and I was amazed at what I didn't know.
James in NC
06-10-2004 20:02:48
If everything else is turning and the pickup reel is not then go to the right side of the baler where the V-belt is. There is a long rod running up from the belt to the belt tightner roller assembly. More than lightly this has been pulled up and is cutting the reel off. Also the belts will always track to the low side of the bale. Put more hay in that side and they will track right.
Hay Dr
06-10-2004 23:14:16
 Re: Re: Round balers in reply to James in NC, 06-10-2004 20:02:48
Preach it brother James
James in NC
06-14-2004 13:36:57
 Re: Re: Re: Round balers in reply to Hay Dr, 06-10-2004 23:14:16
That sounds like something that Page would say.
paul
06-10-2004 18:42:41
Most all round balers - & I only know a few - are built that way. I think you would bust a whole lot of belts if they had ridges instead of the belt guide.
If your belts are off to one side, you are not forming the bales right. You need to wander back & forth over the windrow as you nale, and carefully watch those belts. As they start to wander to one side, they are pointing to the side you _must_ be feeding hay into to balance it again.
--->Paul
