McCormick International 60 Leveling Grader Blade
Paul Johnson
06-10-2004 18:18:42
Question for ya all.. Would a McCormick International A-60 Leveling & Grader Blade for a Super A fit and WORK (most importantly) on a "1945 Farmall A" with an Exhaust Lift-all mounted on it. It looks like everything lines up but I have to question the Lift-all connection to the A-60 Grader implement. My Lift-All is mounted horizontally on the left-side and extends towards the back of the tractor. My Lift-All came off a Farmall B I was told. Thanks in advance!
Paul Johnson
Mark R
06-10-2004 18:28:28
 Re: McCormick International 60 Leveling Grader Bl in reply to Paul Johnson, 06-10-2004 18:18:42
Paul: I know your grader blade will fit because I own a 1944 Farmall A and I have the model 60 blade mounted on it. Works excellent moving snow!
Paul Johnson
06-11-2004 17:58:01
 Re: Re: McCormick International 60 Leveling Grade in reply to Mark R, 06-10-2004 18:28:28
Thanks for the reply, Mark. Does yours use the manual lift or do you use a Lift-All to raise your A-60 Grader blade?
