Fahr tedder
Joe
06-10-2004 17:49:01
I've got a fahr centipede 4 wheel tedder. While tedding tuesday the one center wheel quit spinning (well atleast by the pto). It would free wheel... SO I'm sure you know what happened next, bang bang bang. I don't have any books for this tedder so I was hoping someone could tell me how to get it apart to see what is messed up inside. I took all the arms off but see no way of getting inside. Also it seems like it is spinning out of sequence, with all the arms on the other side's two wheels every now and then they will hit. Do I need to run with some of the arms off? Thanks!
BFarr
06-11-2004 04:05:04
 Re: Fahr tedder in reply to Joe, 06-10-2004 17:49:01
Not an uncommon problem
You likely have a seared pin just above the wheel which it turns holds the "spinnner" in place to engage the gear. You need to replace that metric roll pin.
E-Mail your address or better yet a fax number and I will fax you the parts breakdown on Monday (I believe I own a KH40)
Joe
06-11-2004 12:01:42
 Re: Re: Fahr tedder in reply to BFarr, 06-11-2004 04:05:04
Thank you! The email button did not work, so if you would email me I'll send you my fax.
BFarr
06-14-2004 03:58:20
 Re: Re: Re: Fahr tedder in reply to Joe, 06-11-2004 12:01:42
I cannot e-mail you back either. So send me a ping to [email protected]
Re: parts, I will check my parts book tonight to verify my supplier
Hay Dr
06-11-2004 06:16:18
If you have a consistant parts source in the USA for Fahr equipment please post it. We have calls everyday from people looking for parts.
BFarr
06-15-2004 08:52:53
 Re: Re: Re: Fahr tedder in reply to Hay Dr, 06-11-2004 06:16:18
I have had excellent results getting parts from Knoxland Equipment, Weare NH (603) 529-2366
Wayne in Pa
06-13-2004 06:35:04
I am getting parts for a Fahr tedder thougt a Agco deler.
