IHC steel wheel quack digger
Al L. in Wisc.
06-09-2004 18:27:03
Can someone give me a clue as to the value of a steel wheel IHC quack digger with adjusting wrench. Thanks
Leroy
06-11-2004 06:33:03
 Re: IHC steel wheel quack digger in reply to Al L. in Wisc., 06-09-2004 18:27:03
Never seen an IHC version, evidently not sold in my area, but the JD the Amish in some areas use, sold one to an Amish Friend a few year ago and have seen several setting in their yards, have 2 steel wheel ones setting here now for rebuilding for sale, 8 - 10' will bring several hundred dollars, larger sizes too big, they need the clutch lift
Antiquer in IL
06-10-2004 10:25:41
Those quack diggers are not worth a lot. Most of the steel wheeled ones get the wheels pulled off and the rest is scraped. At most they can bring $100 for a good one. Hope it helps.
Jim in michigan
06-09-2004 20:09:45
I have 3 ,,one is on rubber,,all were free....Best of lick,,,Jim
farmerjohn
06-09-2004 20:09:16
What is a quack digger????
Don-Wi
06-09-2004 20:27:25
 Re: Re: IHC steel wheel quack digger in reply to farmerjohn, 06-09-2004 20:09:16
A quack digger is a feild cultivator(mainly the old ones). We call 'em quack diggers because they're the only thing you can use to get rid of quack grass.
Al L. in Wisc.
06-11-2004 19:26:50
 Re: Re: Re: IHC steel wheel quack digger in reply to Don-Wi, 06-09-2004 20:27:25
Don, where in the Badger state are you located? I'm in Vernon County. And thanks you guys for the input. Looks like I got a worthless piece of old iron. Maybe I should take a drive into Amish country and get a little something for it.
Don-Wi
06-11-2004 22:30:05
 Re: Re: Re: Re: IHC steel wheel quack digger in reply to Al L. in Wisc., 06-11-2004 19:26:50
I live in Outagaimie county,in Kaukauna. I wouldn't say it's worthless. Around here there's lots of collectors with one behind their tractors, and horse farmers use them once in a while. I don't know which part of the state Vernon county is. Donovan from Wisconsin
Al L. in Wisc.
06-13-2004 19:16:46
 Re: Re: Re: Re: Re: IHC steel wheel quack digger in reply to Don-Wi, 06-11-2004 22:30:05
Don, I'm an hour south of La Crosse on the western boarder of Wisconsin=Vernon.
JMS/MN
06-09-2004 22:58:24
Field cultivator with narrow teeth- about two inches wide, used multiple times in a season, like on fallowed ground, to raise quack roots to the surface where they can sit in the sun and DIE. Quack multiplies with runners, so you need to hit them often, pull them up, and hope they die in the sun. Technology from before herbicides.
Rauville
06-10-2004 05:11:14
 Re: Re: Re: Re: IHC steel wheel quack digger in reply to JMS/MN, 06-09-2004 22:58:24
I always remember what an old farmer once said about getting rid of quack. "You have to dig it...rake it...let it dry...burn it...and then, be darn carefull with what you do with the ashes!"
riverbend
06-09-2004 19:46:27
Mine has low rubber and a wrench, that does not appear to fit anything, wired to the frame. It was free.
