Had to bale hay a little damp?
Bob G
06-08-2004 09:23:25
I have had my hay on the ground for over a week now. I turned it on Sunday morning, temps have been in the 60's and rain showers occassionally. They had been predicting rain all week, so I took the afternoon off and baled. Some of the heavier windrows were still damp when baled. I put the bales in the barn stacked on end with three leaning together. It rained over an inch since last night. How long should I leave them stacked this way before putting them in the stack in the barn? I stuck a thermometer in one of the wetter one's to see how hot they get. I know hay goes through a sweat after baled, but how long after and how long does it last?
Thanks,
Bob
bryan g in mo
06-09-2004 16:39:11
 Re: Had to bale hay a little damp? in reply to Bob G, 06-08-2004 09:23:25
as long as you have it standing up , leave it that way for about a week or longer if you feel the need, and it will dry out enough to stack, another ideal ,if it is on a wagon is to cover with black plastic . on a good sunny day that plastic will draw enough heat to dry the entire load out.
INCase
06-09-2004 05:37:04
Boy.... "if it was me" I'd take it out of my barn... been a tough hay year so far in NE and midwest... seen alot of fields get rained on..if you have the barn floor space (or wagon space)maybe spread out 1 layer thick for better air circulation open doors... be VERY careful... cheaper to buy some "good" dry hay than build new barn and contents.. ect ect... we used to let evening "dew damp" baled hay sit on the wagon over night in the shed before putting in barn... rained on hay is worse as its wet all the way thru...good luck
Bob G
06-09-2004 06:25:55
 Re: Re: Had to bale hay a little damp? in reply to INCase, 06-09-2004 05:37:04
I've been checking the temp on the hay since it was baled. It is currently 70 degrees. When I baled it not all of the windrow was damp, only a little in the bottom of the windrows. It is currently standing on end in my open barn. I have the room to let it stay there for 2 or 3 weeks. If it would quit raining I would just move it back outside and let it dry, but we've had over 2 inches since Monday.
Bob G
Bob G
06-08-2004 14:02:16
Not all of the bales are went, I should really say damp. The only one's that were damp were in the heavier windrows where the frass was 5 feet tall.
Bob
Allan in NE
06-08-2004 13:27:54
Bob,
Boy, be careful!
I've watched barns go down like this and it is not pretty. Once it starts, there is almost no way to stop it.
Please make sure that hay is not going to heat on you.....be extra careful.
Allan
Ted
06-08-2004 13:12:25
do a search on the internet, I found an article that accutally had temp curves and times based on research done at a university. I cant remember where I found it, but you can tell for sure when it is safe based on temp and time. Good luck.
paul
06-08-2004 10:46:02
Be real careful with this. Lots of barns burn down.
There is no magical number. At least 5 days, but longer is better, and watch them, don't just go by a calander. Airflow is important, if you can have any curculate through the storage area with open doors, will help.
Other will mention packing with salt, etc. Never did it, but interesting.
--->Paul
JMS/MN
06-08-2004 14:00:19
 Re: Re: Had to bale hay a little damp? in reply to paul, 06-08-2004 10:46:02
My thought exactly when I first read the msg- salt slows down the heating process- sprinkle some on each layer as it goes in the barn. Dad did it years ago with meadow hay, I've done it with alfalfa many times. Can't tell you how much- I guess a five gallon pail lasted for an afternoon of stacking. Now isn't that scientific?
punchie
06-08-2004 14:32:47
 Re: Re: Re: Had to bale hay a little damp? in reply to JMS/MN, 06-08-2004 14:00:19
Hi Forum
Salt the hay !!
Ok Here is How to do Or how I do it. Salt the cut edge.
If hay is just damp , One closed hand full (about 3-4 hepping(sp) table spoonfulls) to each 34" square bale 40-50lbs. Stack hay CUT EDGE UP. By damp I'm meaning baled late or was out in a dew and pick up ealy in the morning etc.
Baled damper After one day starting to fill warm, smell like sour grass (silage smell).
Two closed handfulls.
At two handfulls you should be able to see the salt one the top of the bale, just a little.
Baled Green 60-70 LBS. bales fill like they a bricks, 3-4 closed handfulls bales after 24 hours are hot. NOW WATCH THIS TYPE> reason is they are the trouble makers. They would be the ones to get to the point of a low flash piont, may start a fire. ANd some would say just heavy bales. Will most of the time make good hay.
BALED TOO Green , not going to make good hay. Best not to but it in the barn, But let say you do, I would. I salt it very heavy four open handfulls, place them alone the edge of the mile. I use them for bedding.
Now the type of salt is picking or canning salt white. Brown may have copper in it, should not be used for goats.
About the air drying get them to the point where they would be ok, but would not help cure the hay. The salt and lack of air cure it.
