hale irrigation pumps irratic pumping need advice
hot rod
06-07-2004 18:52:18
trying to irrigate gotta hale pto driven irrigation pump.5" suction line 10'long in past have pumped couple thousand feet all down hill though. at first it was extremly difficult to prime. never had that problem before.got it primed and pumping then it would lose prime and quit pumping did that several times.pulled the suction line out filled it with water while hooked to pump no leaks. got really mad submerged complete pump under water.really easy to prime now(lol)but it'll pump a little and start and stop pumping on it's own.it's not sucking up mud got it off bottom,nor sucking air from surface inlet down too deep.not enough rpm's to cavitate.no drive components slipping.need help before i drown this pump
Chuck MI
06-07-2004 20:47:03
 Re: hale irrigation pumps irratic pumping need adv in reply to hot rod, 06-07-2004 18:52:18
Hot Rod
I had one of these pumps but it's been a few years.
You mentioned that 'in the ran a couple of thousand feet downhill'. What is your output now? If there is too much restriction the pump may heat the water in the volute to a boil and loose prime. Try running with an open pressure side of the pump. If a pump looses prime and overheats, this can cause vacuum leaks at the seals on the shaft, and any PVC or other plastic piping/hose on the suction side. But if it is all under water that is probably not the problem, however make sure you grease that thing up after you pull it out of the pond. Does your priming pump have a ball valve on it and are you closing it after you get it primed?
Let me know what happens.
Chuck
so sorry for duplicate
06-07-2004 18:56:38
stinking dial up connection
