Kuhn teddar repair
Larry S.
06-07-2004 09:37:22
I have a two year old Kuhn four rotor hay tedder, with hydraulic outer rotor lift. The problem I have is that while tedding rye straw, the straw got wrapped up in between the dust shield and gearbox on the two inside rotors. I have cut out as much as possible, but it appears I need to seprate the rotors from the gearboxs to clean out completely. Anybody with information on how to do this successfully would be helpful. I am assuming that the rotor timing must be kept correct otherwise problems will occure there too. Thanks all
