Call the ----- --pany at 1-800-370-3659. They should send you a manual. I bought the same baler last year. I am a part-time farmer and NOT an expert on these balers. On the right side near the front of the baler is a cover that can be removed with two hand screws. There is a drive belt for the pick-up under there with adjustments for tension etc. Your pick-up problem may be there, but there may be no pick-up problem anyway. The pick-up (on mine) will stop when jammed and work again when the machine is cleared. The drive roller is chain driven accessed through the big doors on the left side. I can't find the shear pin in the book. Sorry. These balers are closed throat balers. The newer ones are open throat balers. Unless the hay is in perfect condition, bales are hard to start with a closed throat baler. I think this has something to do with the way the starter roller (the one with flaps on it) is designed. You should also make sure the baler is closed all the way before you bale and that it stays closed when baling. Mine didn't and I had to have the seals replaced in the large cylinders. Hope this helps. You need the manual.
