round baler usage
joe in pa
06-04-2004 18:35:25
can one stop and restart the PTO of a round baler with a partial bale inside. as when moving from one field to another or should one just dump the partial bale and start fresh ??
James in NC
06-06-2004 07:53:31
 Re: round baler usage in reply to joe in pa, 06-04-2004 18:35:25
I don't like to let a bale sit in the chamber any longer that 15-20 minutes. The bale can be hot from the moisture and pressure and cause a fire. The moisture from a bale will rust the sides of the baler. I also don't think that is good for the belts.
thurlow
06-05-2004 06:24:37
Only problem with doing this is if you happen to be using a tractor with leakage in the hydraulic system. Baled in the '70s with a 4020 with problems in the valve box; you had to bump the lever every couple of minutes to maintain pressure or the tail gate would come unlatched.....couldn't shut the tractor off with a partial bale in the chamber. This might not be a problem with some balers, or..... if your tractors are better maintained than mine.
JMS/MN
06-04-2004 22:14:12
There should be no problem with moving from one field to another-actually could do the same thing from one cutting to another, but I suspect that most of us just dump the last bale of each cutting, clean out the residue, and park it in the shed.
paul
06-04-2004 20:28:58
If the hay is good & dry I actually let a 1/3 bale sit in it overnight, but I bet that really isn't a good idea.
No problem for going down the road to the next place.
--->Paul
BUD
06-04-2004 19:03:15
I STOP THE PTO WHEN I AM BALING IN MANY SMALL FIELDS , NEVER CAUSED ME ANY TROUBLE
