Gehl 1310 Bailer not tripping the cutter
Hank
06-03-2004 20:59:41
Does anyone have any idea what to adjust to make the cutter trip and cut the twine? The unit works great as long as it is not bailing. When bailing the tension keeps the needles pulled down just enough to prevent the tripping of the cutter.
So. IL. Farmer
06-05-2004 19:59:42
 Re: Gehl 1310 Bailer not tripping the cutter in reply to Hank, 06-03-2004 20:59:41
Hank; Sounds like you have manual tie on your baler? IF so have, after feeding the twine across the bale.Stop the baler to cut the twine.Thats what my friend does on his 1310 baler with manual tie. Hopes this helps, John.
hank
06-08-2004 06:51:51
 Re: Re: Gehl 1310 Bailer not tripping the cutter in reply to So. IL. Farmer, 06-05-2004 19:59:42
Dear John,
Thanks for your reply. My bailer is electric tie. The problem is that the tension of the twine from the bail pulls just enough to keep the needles from being able to trip the unit, so it will cut. I need to know where to adjust it.
Hank
