How to mount a Detroit Havester Sickle Bar Mower
Tonia
06-03-2004 19:42:46
Can anyone help provide diagram / advice / link to something that would show how to mount an antique Detroit Havester Sickle Bar Mower to a John Deer Tractor 3 Point Hitch?
Tim(nj)
06-04-2004 11:05:45
 Re: How to mount a Detroit Havester Sickle Bar Mow in reply to Tonia, 06-03-2004 19:42:46
What kind of John Deere tractor? All the Detroit mowers I have seen were designed for Ferguson-style 3-point (Ford N tractors, Ferguson TO-30, etc.) or for Case Eagle Hitch (VAC tractors, etc.) If you have a JD 2-cylinder, most likely you have cat. II hitch. If you have a newer JD tractor with cat. I hitch, your hitch dimensions may not be close enough to Ford-Ferguson dimensions to put the mower on. You may end up getting a different mower for your tractor.
Tonia
06-04-2004 12:23:29
 Re: Re: How to mount a Detroit Havester Sickle Bar in reply to Tim(nj), 06-04-2004 11:05:45
They can hook up the mower to the tractor but the handle that raises and lowers the blade is a mystery to them (husband & brother in law). They have all the parts but don't know how to hook them up to work.
Leroy
06-06-2004 18:26:21
 Re: Re: Re: How to mount a Detroit Havester Sickle in reply to Tonia, 06-04-2004 12:23:29
There is NO handle to raise and lower the blade, all done with the 3 point and NO it will not fit on a John Deere as it has to be mounted to the axle where the fenders bolt on on a Ford, the john Deere even if it is a 40-420 series you could not fasten it to the axle as there is no provision on those tractors that you could fabricate the mount for and that Mower has the 1 1/8" PTO shaft not the 1 3/8" on your John Deere, I have 3 of them and all the books, FORGET PUTTING IT ON and get you a corect mower
