RAKING---TEDDING HAY W/ 10 WHEEL RAKE?
BUD
06-03-2004 13:55:17
I HAVE A 10 WHEEL V RAKE , M&W RC5465.THE RAKE WHEELS ARE MOUNTED ON A PIVOT WITH A OFFSET, WHEN I ROTATE THE WHEEL ASSY 180DEG THIS ALLOWS THE HAY TO BE TURNED BUT NOT PUT IN A WINDROW ,DOES ANYONE USE THIS STYLE RAKE TO TEDDER HAY? I SUGGEST THAT YOU TRY IT , IT HAS WORKED GREAT FOR ME.
Tim(nj)
06-03-2004 14:34:33
 Re: RAKING---TEDDING HAY W/ 10 WHEEL RAKE? in reply to BUD, 06-03-2004 13:55:17
Depends on what you're using it in. I had a Gehl wheel rake that could do that. In 4 ton per acre timothy, it was useless for anything but making windrows. 1-ton per acre 2nd cut off the same fields, it worked fine.
BUD
06-03-2004 16:52:54
 Re: Re: RAKING---TEDDING HAY W/ 10 WHEEL RAKE? in reply to Tim(nj), 06-03-2004 14:34:33
THANKS FOR YOUR FEEDBACK , THE FOLKS AT M&W TOLD ME THAT THAT WAS NOT SOMETHING YOU COULD DO WITH THAT RAKE,IT SURE HELPED ME WITH 11 ACRES OF FESCUE 51 ,600# ROLLS.
