JD 347 Sq. bailer
Mike F
06-03-2004 10:40:23
Bailer will turn 180d from 12;00 TO 6:00 in both directions but will not go all the way around. I can not see what is stoping it or what it is hitting on--may have paid to much for this one.
Thanks for the replies
Brokenwrench
06-03-2004 16:52:05
 Re: JD 347 Sq. bailer in reply to Mike F, 06-03-2004 10:40:23
Like was said below,the safety has dropped down and is keeping you from hitting the needles with the plunger. You will probably find that the needle carriage has dropped down while being transported. Pull the needle carriage back up to home,(to the rear and up)and check the condition and adjustment of the carriage brake.One other possibility is the shearpin for the notter has sheared,and left the needles in the chamber.
Mike F
06-04-2004 04:38:56
 Re: Re: JD 347 Sq. bailer in reply to Brokenwrench, 06-03-2004 16:52:05
Thanks for the replies-I'm new to the bailer and will try to find the parts you talk about and there they go--346 wire
Tim(nj)
06-03-2004 12:36:06
I assume you already checked if the safety stop is sticking out by the plunger crank. Is it doing this during a tying cycle (knotters tripped) only or all the time? How about the plungerhead/stationary knife clearances? Fixed a 336 once that had ingested a stone and bent the knives in one place just enough so that they bound.
