JD 214WS Baler - compressor?
Chuck, WA
06-03-2004 07:40:28
My JD 214WS baler came from the previous owner with a bar having multiple flat tines, that hangs from a crossbar above the feed area. The previous owner used the baler exclusively for wheat straw and said he never used it and it just got in the way, so he left it off. It is shown in the parts manual as a "comnpressor", but not in the operator's manual other than a passing reference to what sounds like an adjustment mechanism for it. From its consturction, it looks like it hangs from the crossbar over the feed area with the tines downared and acros the front of the feed area.
Can anybody tell me what is is used for, how it should be positioned, how to adjust it, and what benefits using it will bring in baling grass hay?
Thanks!
Chuck, WA
Kerwin
06-03-2004 15:23:54
 Re: JD 214WS Baler - compressor? in reply to Chuck, WA, 06-03-2004 07:40:28
According to my 24T operators manual, the flat compressor is to help pick up "light, short, or stemmy material" to help get it up to the auger (by holding it down and allowing the pickup teeth to lift it up to the auger). Hope this helps.
Chuck, WA
06-03-2004 15:58:30
 Re: Re: JD 214WS Baler - compressor? in reply to Kerwin, 06-03-2004 15:23:54
Kerwin...thanks! Yes, that helps - kinda along the lines I was thinking. Little hard to picture it working that way until I try it I guess, but if that's what it's supposed to do, it's worth a try. I don't have a lot of that, but some in a few areas where the growth isn't heavy.
Chuck, WA
