505 super I
steven
06-02-2004 05:50:30
I was looking at a vermeer 505 super I baler. I was wondering if a 52 hp. tractor is enough to pull it. Any suggestions? Thanks
Aaron
06-02-2004 13:19:21
 Re: 505 super I in reply to steven, 06-02-2004 05:50:30
I own a 505 SuperI and it is a top notch baler. I've baled 5000 bales and have done nothing but grease it! I highly recomend this baler. As for HP, well that may be a different story. I was baling with an 830 Case (65hp), and it would do it, but she was working. I did have to put in a clutch after the second year. Now I use a 4020 JD, and it plays with it. I do hay on some pretty low ground, and also hills. Flat ground, you may be ok with 52hp.
James in NC
06-02-2004 07:19:23
It depends on what conditions. In the mountians you might be a little low. You can always back off the hyd. tension if the baler is equiped with it. Some had double springs and some had springs and Hyd. Also you do not have to fill the baler up and this will help.
