Bought this pristeen MF 35, pristeen as it is all original but an overhaul isn't too far down the road; nice paint/tin, but not professional. I like the Perkins 3 cyl Diesel.Bought a Service-Rhino 5 ft mower today and want to use this combination to do my mowing. Seems every plade I have to mow is full of obstructions or ditches, or mounds and all the stuff that drives you nuts with a big rig. I want to mow my pond's dam which was built with a 1/3 pitch. To fit the 5' mower, the tires are all the way in (60" outside). I am aware of the "rollover box" associated with your tractor, but on that small of a tractor, 250# of body weight can be shifted to the up-hill side and now the question. The mower is on the ground and is 3pt and as wide as the tractor footprint. The mower is not going to roll over (initiate the action). With the 3 pt connected to the 800# mower, it would have to lift the mower to go over which is "lifting pressure" on the hyd system. Seems this is a pretty good safety valve for those without rops. Looking for your experiences and Ideas you wouldn't mind sharing. Rops is not in the equation as it gets in the way of low hanging trees. Can't even use a vertical exhaust. Thanks, Mark
