caseih 8420 round baler
CDH
05-31-2004 16:59:04
hi fellows I have a problem with baler it don't want to start a roll it chokes up in the throat baled good last year this year all it wants to do is choke up i have read the manual a dozen times it will start a bale after 4 or 5 choke up the belts look ok has good grip when it rolls tried taking the face plate out did not make any diferance at all this baler is about to make me go get drunk and I don't drink Iwould appreciate any feed back Iam a new holland man god bless america CDH
WillHe
06-01-2004 05:22:41
 Re: caseih 8420 round baler in reply to CDH, 05-31-2004 16:59:04
I had a baler like this for two seasons. If the hay is not good and dry you can't get the bale to start rolling in the chamber. You end up with a wad of hay in the chamber and the baler's throat gets plugged too.
If the hay is green enough to cause a square baler to "pound" you will have a hard time starting a round bale in an IH 8420. For me the IH 8420 was a good baler for dry hay, but soon as hay started to draw moisture at twilight, the baler would let me know it was time to stop.
CDH
06-03-2004 03:53:07
 Re: Re: caseih 8420 round baler in reply to WillHe, 06-01-2004 05:22:41
hey fellows I found the problem for my baler bearing on pick up finger got to pull intire pick up off thought i let you all know and thanks for your time CDH
BUD
05-31-2004 19:56:24
I HAD THE SAME TROUBLE,MAKE SURE THAT YOUR BALER GATE IS CLOSED AND THAT YOUR HYDROLICS LATCH THE GATE CLOSED,YOU MAY HAVE A CYLINDER LEAKING INTERNALY AND NOT ALLOWING THE GATE TO LOCK.,I START MY BALE AT ABOUT 500 PTO SPEEDAND WHEN THE BALE FORMS I INCREASE GROUND SPEED .GOOD LUCK
CDH
06-01-2004 03:18:49
 Re: Re: caseih 8420 round baler in reply to BUD, 05-31-2004 19:56:24
Bud the gate latches when you start the pick up fingers act like they cant pull the hay in to the mouth and it pulls it down inthe back of pick fingersthe manual don't give any ideas on this when it makes up its mind to roll it does a good bale Ihave started on both ends of windrow like manual says don't make any differance hay is alfafa/orchard grass later CDH
sparke
05-31-2004 17:32:48
Don't know about an 8420 baler,but on my 8440 baler this usualy means it's time to replace the starter flaps.
CDH
05-31-2004 17:44:12
 Re: Re: caseih 8420 round baler in reply to sparke, 05-31-2004 17:32:48
Hi sparkey the 8420 does not have starter flaps it has a 4"square box where the starter flap is my neibor told me that also he looked at it and could not help me Iknow some one out there can feed some light on it i appreciate your message have a good one CDH
