Hesston 3717 Tedder
So. IL. Farmer
05-29-2004 20:32:12
Today the AGCO dealer delivered me a Hesston 3717, 4 basket tedder to try out.I noticed the ID tag said that it was built in Italy by Rossi.Does anyone have any experiance with this model? What are there weak areas? I noticed that Rossi builds tedders for alot of other equipment companies.I know Hesston did build fairly good hay equipment. Thanks for your imput. John.
kyhayman
05-30-2004 07:37:42
 Re: Hesston 3717 Tedder in reply to So. IL. Farmer, 05-29-2004 20:32:12
I've got the NI version of your Hesston. 2 things to watch ( that I have found)
1. 1 take the time to set the height. Ground contact can bend the arms. A bent arm on baskets 2 & 3 can hit the bottom (back corners) of the gear box. About 3 hits and you have a hole. Were I getting a new one I would weld a pc of steel angle on it before I ever used it.
2. A groundhog hole is just pefect to break off one of the wheels, usually right below where the spinner mounts.
Main thing I found is to slow down ground speed. I could ted in road gear but bouncing is what bends the arms. I ted at 50% of the speed I mow. Net is it takes as long to ted as it does to mow but does a way better job with way less damage.
