Landpride 2560 blade replacement
Gary
05-29-2004 12:47:18
Having trouble getting the blades off. Are the reverse threads (manual doesn't state)? Any tips on getting them off. I just got this with the house purchase and two of the blades are partially broken.
Steve
06-14-2004 01:38:56
 Re: Landpride 2560 blade replacement in reply to Gary, 05-29-2004 12:47:18
Go buy an air compressor and a "good" impact wrench (CP or Ingersoll Rand). It will come in handy for lots of things. In few weeksyour wife will be wondering how you ever got along without it and fathers day is just around the corner.
Steve
BobMo
05-29-2004 20:43:01
Gary, they aren't left hand threaded, they'er just hard to get off. Use a 3/4 drive if you have it and a 3-4 ft. cheater. I've broken 1/2 drives so don't waste my time with them anymore. If you remove them a couple times a year you won't have any problems with them..... .....Good luck.
gary
05-30-2004 07:05:21
 Re: Re: Landpride 2560 blade replacement in reply to BobMo, 05-29-2004 20:43:01
Sorry, a couple of more questions. I am using a 3/4 socket but unfortunately don't have a decent size breaker bar (guess it is time to get one). What do you use to keep the blades from turning? Currently I have the mower on the back of the tractor lifted up and am trying to use a block to keep the blades from turning.
Thanks for your help.
BobMo
05-30-2004 15:34:43
 Re: Re: Re: Landpride 2560 blade replacement in reply to gary, 05-30-2004 07:05:21
Gary, you don't need to keep the blades from turning. The blade rotates on the bolt (shoulder type) and bolt is keyed to the disc in the center. If you are going through the port on the deck just let your extention come up against the side of the whole in the deck.
fox
05-30-2004 18:04:43
 Re: Re: Re: Re: Landpride 2560 blade replacement in reply to BobMo, 05-30-2004 15:34:43
I wrap a heavy rag around the blade and or use leather gloves.
Grab the blade with one hand and the brakerbar with the other.
When you put it back together use some antiseize lube.
