Locking pin in u-joint for pto shaft
TLO
09-06-1999 08:57:46
I have a300 farmal and the ujoint tha slips on the pto shaft comes off during operation I removed the spring loaded locking pin and found that it was worn smooth in several places and would not lock in the grove that is on the pto shaft my question is this is this part replaceable or does it have to be made by a shop.Thanks for any help yopu could send this way.
Hey busdriver Please don't stop
09-06-1999 20:39:41
 Re: Locking pin in u-joint for pto shaft in reply to TLO, 09-06-1999 08:57:46
If you can get one reasonable enough to replace it with ,fine. I had one that was not suitable for replacing so instead replaced it by drilling it out and replacing it with a regular bolt, it takes a minute or two longer to put on , but it is safer than the one that one was on there. I used a double nut to make sure it locked it on.
PTO shafts coming off can be lethel, always practice safety first. Safe tractoring.
Stan
The Red
09-06-1999 09:46:59
T take a look at 3 threads down and sort through them. That question is answered in there. You should beable to get that replaced.
