conditioner hookup to a 501 ford mower.
Gary in MOzarks
05-29-2004 05:38:46
Hello, Has anyone know of or ever seen how they hook a conditioner to the back of a 501 mower? I saw a picture on a ford brochure that showed one. I assume they must have had a pto extenion that bolted on to the back of the sheeve and some kind of tow bar setup. Ive got a good running 501 mower on a IHC 424 tractor and I'd like to buy a neighbor's conditioner, if I can figure out how they hooked up. I can't afford a haybine.
jc
05-29-2004 06:50:41
 Re: conditioner hookup to a 501 ford mower. in reply to Gary in MOzarks , 05-29-2004 05:38:46
If you'll notice there are square holes in the spokes of the sheeve in the rear. These are the attach the PTO extention that you mentioned by means of carriage type bolts. The drawbar is two peices shaped to clamp around the mower frame and bolted together. Probaly get a shop to fabricate unless you do that stuff. Get the conditioner even if you make two passes it's cheaper than a mowco.
