?? cut my hay how to figure to right way to Fert
anthony
05-27-2004 13:53:44
Hi Live in central Texas and after I bale my hay I want to fertilize the coastal fields its black clay. I have 20 inch spaces & 20 spray tips on my boom sprayer & tips spray 20 gallons per acker Hardi tips at 40 pounds pressure. I want to be in 5 th gear at 5 mph. Using 32-0-0 fertilizer.How do you calculate get 250 pounds per aker thats when we use dry now with liquid?? thats my question?
Greywolf
05-28-2004 05:09:52
 Re: ?? cut my hay how to figure to right way to in reply to anthony, 05-27-2004 13:53:44
Take 2.5 times the analysis numbers to achieve the actual pounds of product applied.
ex... if you are having 250# of 9-23-17 (just some numbers for example) that would be 22-57-42 of actual applied.
28% weighs 10.7#/gal, not sure on the weight of 32% but I would use 11#/gal as a guideline for "rough" figuring. Fertilizer isn't critical like herbicides are.
To achieve 22# of N with 32-0-0, take 22 divided by 32 which equals 69# of 32% or approxiamately 6.25 gallons.
If you have an "in house" blend of liquid made up to replace dry. Be careful on the K product. Most contain clay/salt particles that WILL NOT pass through an average farm sprayer.
paul
05-27-2004 14:53:15
I never used liquid yet, but you need to tell us what fert you are using, I believe there are different products.
Then, if you want 250 lbs per acre actual N (wow that sounds like a lot!), or do you mean you used 250lbs of 32, or about 80lbs of N per acre?
I believe you might need bigger tips on the sprayer, but as I say I'm not experienced. Seems that would be a lot of liquid, they might do split applications of liquid, 1/4 or 1/3 after each cutting?
--->Paul
