Need Recommendation on Disc Size
PKurilecz
05-27-2004 09:22:38
Hello All:
I have a 32 Hp Ford 1910. I want to buy a disc for it. I am trying to decide between a 5 foot and a 6 foot wide disc. Obviously, I would prefer the 6 foot disc, but I want to make sure that I will be able to pull it. The soil is a sand.
Thanks for your help.
Pkurilecz
05-28-2004 07:33:10
 Re: Need Recommendation on Disc Size in reply to PKurilecz, 05-27-2004 09:22:38
Hello All:
Thank you for the recommendations.
A five foot disc would just cover the tracks with the way that I have the wheels set.
It sounds like I will get a six foot disc, maybe seven if the price is right.
Cheers;
PKurilecz
txblu
05-28-2004 18:05:46
 Re: Re: Need Recommendation on Disc Size in reply to Pkurilecz, 05-28-2004 07:33:10
Disregard the comment below. It was for a shredder question, not a plow question. But if your plow is/is to be 3 pt, it could still have some merit considering pulling power required and lift on the front of the tractor, and hydraulics power required to lift it.
I went to dinner and lost track of where I was .
Sounds like you are headed in the right direction.
txblu
txblu
05-28-2004 17:59:24
Ahhhhh ! When you said 7 better think it over. Everything is proportional to cutting area.
Size -- cutting area -- increase
5' -- 19.6 sq ft
6' -- 29.3 ----- 44%
7' -- 38.5 ----- 96%
A 7' is a big machine and weighs proportionally, sticks out proportionally farther back from the tractor so load on hydraulics and front end lift is proportionally higher, plus terrain variations are much more apt to be a problem and with all that mass turning, if you hit something, your ability to wipe out your tractor's drive line is directly proportional (if your slip clutch/shear pin fail which they have been known to do).
Then there is the cost and the HP required to turn the blade.....get the point?
Think about it.
txblu
txblu
05-27-2004 11:55:30
You can always lift a wide one out of the ground if it is too hungry, but you can't cover your tractor tracks with a narrow one.
ShepFL - amen to that !
05-27-2004 13:21:12
 Re: Re: Need Recommendation on Disc Size in reply to txblu, 05-27-2004 11:55:30
Get something wide enough to cover your tracks. Smaller disks mean more seat time with a light weight implement (not overly productive). Consider 6-7 ft. if your rig will handle it.
Few yrs. back I traded up to IH #37 Transport disk (10 ft) and have not looked back. Works good provided I do not get it to deep to overpower my tractor.
Bob Jarvis
05-27-2004 09:26:33
I've got a seven-foot disc I pull through clay with a 33 hp Ford 3000 and it does fine. I expect your tractor will be able to pull a six foot disc.
