NH 66 Baler
Paul White
05-27-2004 04:31:05
Just checking my NH 66 that I bought at an auction late last fall and when I run the knotter through its cycle only one side ties. The right side ties alright but the left side is not tied. I can see where the string is flattened from the cylce of the knotter but no knot. The book does not talk about this . Any ideas ?
Steve from New Holland
05-28-2004 04:32:59
 Re: NH 66 Baler in reply to Paul White, 05-27-2004 04:31:05
Paul, can you help us with a little bit more info. Does either end of the string have a loop on it or are both ends untied? If one end does have a loop, which one is it? Any other specifics would help me. Let me know and I will try to help. Steve
Paul White
05-28-2004 06:33:42
 Re: Re: NH 66 Baler in reply to Steve from New Holland, 05-28-2004 04:32:59
Steve; Neither end has a loop or knot in it. Both pieces look flattened like they went through a motion but no knot. I will have to get sombody to turn over the baler as I watch more closely. Hard to do myself.
BFarr
05-27-2004 07:27:00
As with all knotters, a number of adjustments be causing a missed knot. I would suggest you check all clearances via the book and compare the two knotters at each point of the cycle as you hand cycle the machine
