Baler engine
Bernie in MA
05-25-2004 17:49:00
I'm replacing the head gasket on my baler engine. It's a two cylinder Wis. Should I use never-seize on the head bolts? I broke one off taking it apart, had to drill and tap.
Jim in michigan
05-26-2004 20:09:42
 Re: Baler engine in reply to Bernie in MA, 05-25-2004 17:49:00
I would,, couldnt hurt anything thats for sure. I may have found a final drive,, its from a JD 40, supposed to fit my 420, I hope it will,, price is right . Do you know if it will work? Thanks,,,Jim
Bernie in MA
05-26-2004 06:39:59
Thanks guys. I got new bolts and going to borrow a torque wrench to put it together today.
Steve from New Holland
05-26-2004 04:32:14
Bernie, definately a good idea. Also, run a tap through all 17 threaded holes in the block first. Then torgue bolts to 25 ft lbs and retorque after about 10 hours. Steve
Dan
05-25-2004 20:10:06
It's worth a try but may not help. They run very hot and tend to weaken the bolts so they bread when you take them out. I would use all new bolts and torque properly.
