Tires for New Holland Rake
Joe
05-25-2004 15:39:42
I'm having problems with the NH 256 rake wheels sliding in thick and wet hay and thought I would replace the worn out slick tires with some tractor lugged ones like it would come with new. My manual says 5.00 x 15 tires, but the ones on the rake are just plain 14" passenger tires. I suppose that makes my rims 14" and I will have to find tires to fit them.
Philip
05-29-2004 19:24:03
 Re: Tires for New Holland Rake in reply to Joe, 05-25-2004 15:39:42
I have a 256 NH rake. I have Volkswagon tires on it that were capped and are mud grips. I only have one side that pulls because the lock in spring on the other side is broken. It has worked like that for several years.
TP from Central PA
05-25-2004 19:14:24
If you have 14's on it now you could definitly get some Ag. tires for a garden tractor that would mount on those rims..... ..... ..Just a thought....
Steve from New Holland
05-26-2004 04:29:28
 Re: Re: Tires for New Holland Rake in reply to TP from Central PA, 05-25-2004 19:14:24
Not sure how you got 14" tires and rims on your rake. It is supposed to have 5:00x15" traction tires on 4" wide rims.
txblu
05-27-2004 09:29:01
 Re: Re: Re: Tires for New Holland Rake in reply to Steve from New Holland, 05-26-2004 04:29:28
Sometimes you just don't see the forest for the trees. I don't know how many times I looked at those tires never thinking that since it is ground driven the lugs are for traction.
This site just makes and keeps you aware of things. Great place, great folks.
Oh well.
Mark
paul
05-27-2004 14:48:18
 Re: Re: Re: Re: Tires for New Holland Rake in reply to txblu, 05-27-2004 09:29:01
And, since it is driving the axle (instead of the axle driving the wheels), they should be mounted on the implement 'backwards' from a tractor tire.
--->Paul
