Early Detection
Mike
05-25-2004 14:51:03
I am wandering if anyone makes something to detect bearing problems before they really go out, or if this is even possible. Maybe like some type of heat sensor, other than my hand. Anyone ever heard of anything like this?
Curious about this one.
Mike
Pat
05-27-2004 14:18:00
 Re: Early Detection in reply to Mike, 05-25-2004 14:51:03
Yes, but BOY are they expensive. I provide engineering support to the Marine Corps H-1 helicopter program. These aircraft are going to be remanufactured, and will have a state-of-the-art system to monitor bearing and gear failure, well in advance of potential failure. Lots of accelerometers, and significant recording of data. The goal is to be able to pinpoint which bearing in which gear is the bad actor, and to provide many hours of warning prior to failure. Or, use the broom handle/piece of hose, as suggested by others. This system will set you back the price of a nice house.
Pat
Hugh MacKay
05-26-2004 18:25:35
Mike: If you are a low budget guy just cut off your good wife's old broom handle. Cut it square on both ends. Place one end on or near the bearing, and put your ear up to the other end. You will hear a lot. Works best on engine, transmission and rear end noise.
Jack your tractor rear wheels very securely, put tractor in gear about 1/2 throttle. Then go around the tractor with the broom handle. Truly amazing what you will hear. I can't emphasize enough in having the tractor secure, especially if checking some of the higher gears. I use a pallet jack and put a good hardwood pallet with good square blocking under rear end. Tie down straps over axle housings to the pallet make it secure. It's kind of one of those, listen to your tractor once per year items.
Jim
05-26-2004 15:52:46
Mike,
There is an instrument made called a shock pulse meter. It works by measuring the vibration caused by imperfections in the internals of a ball or roller bearing. To use the instrument, you must make an initial setting of the bearing diameter and the speed. The meter then reads the shock pulse of the rollers as they pass the imperfection in an inner or outer race. The meter provides a rough reading - red for expect failure very soon, yellow for damage and you got time or green for good condition or longer life expectancy. The instrument is expensive and makes sense to purchase if you are in maintenance in an industrial plant.
Shep Va
05-25-2004 20:03:53
Get an infered thermometer (sp) off ebay or one of the tool catalogs and use that to check the temp of the bearings compared to the others. Works great and you can spot the bad ones sooner.
Allan
05-25-2004 15:32:28
Hi Mike,
Yep, the railroad(s) have been using heat detectors mounted on stands along the railways to monitor wheel bearings for many, many years now.
The bad guys are usually sensed before they fail.
Allan
