need to find place for used Vermeer parts
mel
05-25-2004 11:51:13
Where is there a junkyard that sells used Vermeer balers parts?
Hay Dr.
05-25-2004 13:09:32
 Re: need to find place for used Vermeer parts in reply to mel, 05-25-2004 11:51:13
If you want a 4039-001 roller you can likely can have a machine shop fix it for $150
paul
05-25-2004 16:41:13
 Re: Re: need to find place for used Vermeer parts in reply to Hay Dr., 05-25-2004 13:09:32
If this would be, like, a drive roller for a 605F for example - yup, and made one is better built that the original was.
My machine shop just started from scratch. I was baling for a friend, the last bale the shaft broke last year, he paid me $200 for the baling, & with 2 new bearings the new shaft cam to $198. Kinda funny.
A gearset would be about the only thing to try to find I suppose?
--->Paul
James in NC
05-25-2004 12:46:45
We have several balers that have gotten to hot, or that it did not make sense to fix. Where are you and what are you looking specificly for? We are located in Warrenton, NC.
James
mlm
06-09-2005 09:30:11
 Re: Re: need to find place for used Vermeer parts in reply to James in NC, 05-25-2004 12:46:45
hey, James in NC, if you see this , what would want for the two pick up springs and their center tubes?
Later balers used the same parts.
Also the rubber roller would be ok.
mel
06-02-2004 11:32:38
I am in Michigan. baler is an old 605c
