JD 246/247 planter
pappy
05-25-2004 08:59:08
Spent sunday afternoon trying to get the above "gift" working. The sheet metal interior of one of the seed drops was bent badly at the bottom end. After straightening and a little trimming it now appears to work but do to tractor difficulties, discussed elsewhere, I was unable to test the implement on the ground. Is the only test the actual planting?
JI nutCase
06-02-2004 19:45:34
 Re: JD 246/247 planter in reply to pappy, 05-25-2004 08:59:08
Lower it to engage drive wheels,and pull it across hard clean ground, I usually do it in the driveway in front of the shop, measure off 13'4". Count the number of seeds in that distance. Take the seed count and multiply that by 1000 if you are on 36" rows. and that will give you actual population per acre. Aaron
Coaltrain
05-25-2004 09:17:52
Pappy I lay down a cloth tarp or sheet and run planter over it, (for small seed) to check seed population and spacing. 246/247 are horse drawn right? Coaltrain
pappy
05-25-2004 12:36:46
 Re: Re: JD 246/247 planter in reply to Coaltrain , 05-25-2004 09:17:52
Thank you for your reply. 246/247 John Deere is a 3 point two row, made until the late 1950's, I think.
Leroy
05-25-2004 19:05:16
 Re: Re: Re: JD 246/247 planter in reply to pappy, 05-25-2004 12:36:46
Made from early 50's, starting with the 40 tractor, the 246 is the corn version, 247 the cotton version, seed parts same with all 290, 490, 494, 1200 series plate planters
pappy
05-26-2004 10:40:12
 Re: Re: Re: Re: JD 246/247 planter in reply to Leroy, 05-25-2004 19:05:16
Any good ideas on replacing the fertilizer hoppers? A new guy question.
Leroy
05-27-2004 05:44:41
 Re: Re: Re: Re: Re: JD 246/247 planter in reply to pappy, 05-26-2004 10:40:12
have not gotten around to checking, I have several on planters to rebuild for sale, that need new boxes but I think that the large round can seed hoppers from the later 494A type planters are the same diameter and that was what I was thinking about getting from a parts yard and using on mine
pappy
05-29-2004 12:13:59
 Re: Re: Re: Re: Re: Re: JD 246/247 planter in reply to Leroy, 05-27-2004 05:44:41
did the 494 use metal or plastic fertilizer hoppers? thanks
Leroy
06-06-2004 19:35:39
 Re: Re: Re: Re: Re: Re: Re: JD 246/247 planter in reply to pappy, 05-29-2004 12:13:59
If Deere used a plastic Fert Box it was in the 7000 up planters
Tim(nj)
05-26-2004 14:53:49
If you've got the bases, a sheet metal shop can roll you new cans to fit them. I'd get them to use stainless if possible.
