Int 435 baler
Jim in NC
05-23-2004 04:15:11
I got my baler out for the first time this season yesterday. After baling about 15 to 20 feet, I sheared a bolt. The 2 knives in the chamber were hitting each other. The plunger is not sliding in the center of the chamber. The plunger can be pushed over so that it clears the stationary knife but when it clears the knife on the return stroke it moves back to the colliding position. Does the wooden shim on the top rear of the plunger take out this play? If not, what is causing the plunger misalignment? Thanks in advance for your help. By the way, the baler was working fine when I put it up last fall.
havvey
05-26-2004 18:36:00
 Re: Int 435 baler in reply to Jim in NC, 05-23-2004 04:15:11
could be wood could be the roller ball bearings on the plunger there is also an adjustment on the gear box side for the plunger on a long rail just a few thoughts.
