Planter marker Cables
JM
05-20-2004 08:28:22
How do I go about changing my planter marker cables on my older 7000 4 row planter
paul
05-20-2004 08:52:48
 Re: Planter marker Cables in reply to JM , 05-20-2004 08:28:22
Buy the manual, follow the directions. ;)
Let the right side down, unhook cable. Unhook the front of that marker, pivot to rear. Remove the 2 bolts holding the hyd assembly inside the tube.
Take the cable off the left marker - tie a rope on it, much easier to fish it back through. (Depending where you start from, might want to take this cable side off first - whichever)
Pull the hyd assembly out the right side.
Whatever you need is there in front of you.
--->Paul
