I'm an X city boy with no training. 25 years ago I bought a Miller 200A ac STICK welder for $135. I experimented until I could please me (it held, not necessarily pretty). I always liked the smaller rods around 3/16, 1/4 max, which could be run at lower currents (not over 150A). This helped me get the job done as the welder was duty cycle limited and had to be watched so it wouldn't overheat. After lotta years and the kids getting on their own, I decided to give the welder to a son and upgrade. First was a 200A Miller ac/dc stick which produced beautiful welds with the 7018 rod ($300). I could weld sheet metal with this rig if using the 3/16 rod which is what I used on almost all but the most demanding welding. (Bigger rods are just sitting in the cooler). Was in TSC one day and they had their MIG type wire welders on sale for $200 which did not require bottled gas. Used flux in the wire like flux core solder for (radiator or electronics repair). This is real handy and can almost weld paper but not pretty. I think you need to upgrade to a gas unit to get it pretty. What I like about it is I don't have to wear the helment required with the other welder. In the summer time that is great. It uses a hand held shield for your eyes. I like both. Could have done without the wire but like it and use it. I bought the last stick the dealer had and that was 5 years ago. Don't know if they make them anymore. You can teach yourself to weld or get a book. Hope this helps, txblu
