What do you know about a Brillion seeder?
Kelly C
05-18-2004 20:21:02
Looking to rent one for my Alfalfa/ Timmothy with a Oats cover crop. Dont know any thing about them.
JMS/MN
05-20-2004 21:36:38
 Re: What do you know about a Brillion seeder? in reply to Kelly C, 05-18-2004 20:21:02
A Brillion seeder is an excellent machine, but no better than pulling a cast iron or rubber packer behind your grain drill. Purpose is the same- packs the ground, pushes down the rocks, makes a good seedbed for the grass seed and alfalfa. If you got a good alfalfa stand with 15 lbs per acre before- you can seed 10-12 lbs with a packer for the same stand. You don't need a smooth field- the packer makes the field smooth. Two secondary tillage passes with a disc or field cultivator, and seed with a Brillion or drill with packer=great seed bed. Especially good on the lighter soils north of the TC. Only drawback with a packer is on heavier clay soils, might cause some crusting, or on rolling ground, might wash the seed into the lows. Typical year tho- good idea to use the packer or Brillion.
Judy Greenaway
05-23-2004 10:53:28
 Re: Re: What do you know about a Brillion seeder? in reply to JMS/MN, 05-20-2004 21:36:38
I would like to know how to remove the bar to take the brushes out of the back seed bin. I have a 12 foot brillion seeder the bar is split in the middle and I have been able to get the one bar out. The other bar on the right looking at the seeder face on has not been so easy to remove. Do I have to remove all the bearings or is there a simplier way.
Thanks Judy
RichG
05-19-2004 09:39:47
The brillion works perfect for hay seeding. I've used one on all my fields. Just make sure that your fields are smooth. Joe at Petersons Mill rents one (10') for I think around $8 an acre. Also let me know if you get up some good alfalfa mixed hay, a few of my customers buy it and I don't put anything except grass up.
Delbert
05-19-2004 08:05:51
Best way to plant alfalfa leave ground alittle rough and it will do a good job. The ground will be as level as the floor. Talk to the people you will rent it from for more info.
