Dearborn Disc Plow
Robert Young
05-18-2004 15:00:06
Looking for disc blades for a Dearborn Model 10-80 2-bottom disc plow. 20-1/2 +/- diameter, 5 hole bolt pattern, 4-3/4 inch bolt centers.
ShepFL
05-19-2004 05:44:06
 Re: Dearborn Disc Plow in reply to Robert Young, 05-18-2004 15:00:06
Not sure where you are located but I found a fella in Lake City, FL that sells them. Faul's Farm Supply 386.755.0027 located on Hwy 441.
They are blanks and you torch out the holes to fit. I clamped my old disk to the new and just torched out the holes. Then with a grinder I cleaned up the holes.
If I recall they are 12mm thick (nearly 1/2") with a nice beveled cutting edge. I replaced both my disks this spring. Cost is $30 each vs. $60-70 for ones with pre-drilled holes. Given the thickness of the material it will be a LONG, LONG time before I need to replace again. They work great.
