Pulley on bush hog finish mower
Scott Paulman (
05-18-2004 10:44:55
I recently acquired a Bush Hog finish mower that is missing one of the belt pulleys. I looked at it briefly last night and there is an approximately 2 - 2 1/2" ring with a radial cut that appears to be holding the pulley on. There was one bolt running throug this ring and into the pulley. What is the proper way to remove this ring and ultimately the pulley? Should I just drive a screwdriver into the radial slit to spread the ring open? Will the pulley then just slide off or will I need a puller of some sort? Thanks!
