New sickle mower
Butcher
05-17-2004 17:45:39
third party image
OK. I got stupid. Again. I bought this mower from a guy across the section. The only #'s I can find on it are 15404-R2 IH. Someone has aborted this thing really bad. I got 4 extra bars with good blades with it and the pitman is in good shape. I am going to do some cutt'n and wielding to make it work on my 1750 Oliver. I was just wondering what this thing was origonally. Trailor type or drawbar or what? I got a use for it where I can not get with the brushhog or I would have let it set in the weeds. Thanks.
Jim in michigan
05-19-2004 07:20:25
 Re: New sickle mower in reply to Butcher, 05-17-2004 17:45:39
looks like a 27V,,I have one up for sale right now,, great mowers, I just dont use it anymore,mine is set up for a C or Super C,, has a cable lift that works off the touch control...Jim
ihkovas
05-19-2004 00:18:42
Butcher, that is a 27V that you have hanging there. Is that a hand lift lever bent down or a hose for a cyclinder to lift the cutter bar? Altho the 27V didn't come with a cyclinder mounted on the frame,I've seen two with identical add-on brackets.
Rich Iowa
05-18-2004 16:23:43
that mower looks like a IH 31 mower, I have one, mine works real good. If I remember right, on the 25 and 27 mowers, the triangular frame is offset while the 31 angles straight back. if you decide you don't want/ need it, i'd be intersted in taking it off your hans, where bout you located?
Butcher
05-18-2004 18:42:01
 Re: Re: New sickle mower in reply to Rich Iowa, 05-18-2004 16:23:43
I am 12 miles N.E. of Waterloo. I been out in the shed tonight trying to figure out what someone has done to this mower. And also what I am doing with it. Somebody has made some really poor modifications to it. All I need to do right now to make it work is lengthen the pto shaft. I'll look around for some other numbers on it towmorrow.
JMS/MN
05-17-2004 20:16:20
You have a semi-mount mower. A trailer type mower would have two wheels and a hitch that attaches to your drawbar with a single pin. A mounted mower would attach either to a tph or the tractor frame itself. The front part of your mower likely attaches to a tractor drawbar (parallel to your tractor rear axle) with at least two bolts, and the single wheel behind just pivots as you make your turns.
Dick Davis
05-18-2004 04:15:59
 Re: Re: New sickle mower in reply to JMS/MN, 05-17-2004 20:16:20
Don't know the model of that mower but I've got two that I use. They are McCormick's and I like them. Would like to know the model number. People call them 25, 27 or 27 V's but it is a newer Model than those. My nickel Dick Davis
