Identify older hay rake
glenn
05-17-2004 13:52:24
Im trying to replace a few parts,but there is no name plate or id tage. frame is red and larg drive wheels on either end are yellow.Axel drives chain drive to spocket it has a short drive shaft that is conected to the gear box.Could i be new holland? thanks for any Help GLENN
Sam Bauder
02-17-2005 18:22:00
 Re: Identify older hay rake in reply to glenn, 05-17-2004 13:52:24
I have an international harvester model 15 parallel bar rake that has a chain from the drive wheels to the gear box, do you have any pictures?
Stan - Florida
05-18-2004 03:46:41
Another one that comes to mind is a Massey-Harris...those colors sound right for M-H. Cockshutt would also be a possiblity.
Good luck,
Stan
Jimmy king
05-18-2004 05:16:37
 Re: Re: Identify older hay rake in reply to Stan - Florida, 05-18-2004 03:46:41
I still have a Massey it was the first of the 2 wheel rakes, 6 bar, no chain drive on them.
Stan - Florida
05-18-2004 05:45:03
 Re: Re: Re: Identify older hay rake in reply to Jimmy king, 05-18-2004 05:16:37
Jimmy,
When he mentioned the "large drive wheels", I thought of an older rake with steel wheels and possibly 3 or 4 bars, not one of the modern-day rubber-tired ones...when I say "modern-day", I mean anything after the mid-'50s - LOL!
Stam
Jimmy King
05-18-2004 10:29:55
 Re: Re: Re: Re: Identify older hay rake in reply to Stan - Florida, 05-18-2004 05:45:03
You are right Stan, but some of the modern ones had chain drive I just don't know which ones except New Holland and Massey New Idea had belt drive. Of the older rakes we had a Ihc and a David Bradly and I don't remember if either one or both had chain drive that has been 45 years. LOL
Leroy
05-18-2004 05:53:32
That is what I am wodering also. Parallel bar or 45* bar and no. of bars and no. of wheels, 2 large in front with 1-3 small in back?, ground drive or pto?
old
05-17-2004 20:23:34
Sounds almost like one I'm fixing up but I have found IH on a place or 2 but other then that I have no idea what it is. Look your over real good most of the time there is something on it that will tell you
Jimmy King
05-18-2004 13:52:29
 Re: Re: Identify older hay rake in reply to old, 05-17-2004 20:23:34
"Old" I blow my air horns every night when I cross the bridge between 11:00 and 1:00. Jim
old
05-18-2004 15:26:59
 Re: Re: Re: Identify older hay rake in reply to Jimmy King, 05-18-2004 13:52:29
Well so far I haven't heard it but I'm in the house at that time of night.
rustyfarmall
05-17-2004 17:55:18
The colors sound correct for a New Holland, but I won't say for sure.
paul
05-17-2004 19:07:11
 Re: Re: Identify older hay rake in reply to rustyfarmall, 05-17-2004 17:55:18
NH that I know of is all gear drive - model/serial plate is on the gearbox. Never saw a NH with chain, but I sure haven't seen everything. :)
---Paul
