NH 275 shear bolts.
N Puller
05-16-2004 20:29:31
I HAVE A 275 NH BAILER THAT THE FLYWHEEL shear bolts COME LOOSE.MAKE 20 BAILES STOP TITEN THE BOLT ALL OK.I HAVE REPLACED THE BUSHIHGS IN THE FLYWHEEL AND IT HAS NOT HELPED.WHAT DO YOU ALL THINK?
oh my god you answered yo
05-18-2004 01:26:14
 Re: NH 275 shear bolts. in reply to N Puller, 05-16-2004 20:29:31
oh my god you answered you own question NH 275 shear bolts this don't mean hardware store bolts this means use New Holland shear bolts with NH lock nuts they are made fore this reason
they will not come loose in one day after thousands of bales maybe but you will shear it long before it dose or your not working verry hard
shim the flywheel so that it can't move front to back verry much if you are using newholland shear bolts
N PULLER
05-18-2004 14:54:09
 Re: Re: NH 275 shear bolts. in reply to oh my god you answered yo, 05-18-2004 01:26:14
DID I SAY hardware store bolts?I USE NH BOLTS FROM THE NH DEALER!!!!!
paul
05-17-2004 21:36:55
Lock nuts will help with the problem, tho one of the other messages probably contains the _cause_ of the problem.
Not sure, anyone ask if the shear pin holes are worn oblong, that lets the pin wobble & causes the bolt to loosen as well.
--->Paul
Matt K
05-17-2004 08:17:01
With the shear bolt out can you move the flywheel from front to back? We had a 276 NH that kept shearing bolts, shimming the flywheel so that it couldn't move front to back cured it.
Steve from New Holland
05-17-2004 04:37:26
Had a baler like that years ago that drove me nuts. Could not figure it out. Finally figured out the input shaft that the flywheel rides on was slightly bent. Check it out. Steve
JMS/MN
05-16-2004 22:01:10
Are you using the proper nut on the shear bolt? Is there wear in the drive casting?
Alex Rogers
05-17-2004 18:56:00
 Re: Re: NH 275 shear bolts. in reply to JMS/MN, 05-16-2004 22:01:10
Are you using a washers on either end and a lock washer on the nut end of the shear bolt?
