Ground driven hub id.
Keivn Koler
05-16-2004 10:05:24
Hi - I am trying to identify who the maker is of a hub on a ground driven hay rake. The #is h4387m and below it is WN. If it helps the hub is red but the matching wheel with the teeth is green. I need to replace the ratchet on the hub on the axle. The maker of the rake was David Bradley but I am not sure if the hub is standard equipment. Thanks Kevin
