Plow Parts
DP
05-16-2004 06:41:41
Looking for sites to plow/shares/moldboards/landslides/shins and what ever else might be needed. Am fixing up a couple John Deere plows. Thanks for any leads.
dieselrider
05-16-2004 15:54:11
 Re: Plow Parts in reply to DP, 05-16-2004 06:41:41
Try agri-supply.com
riverbend
05-16-2004 11:38:45
I think most of those parts are available at the dealer. You might want to take some of the old ones with you. 16" four bolt throw away shares were $15 ea. Plate landsides were about the same. Cast iron landsides were $35 (?) each. The old style resharpenable shares (with the tooth on the front corner)were close to $100. There are aftermarket parts for less, but you might need to know the part numbers. The moldboard had it's number stenciled on the back.
DP
05-16-2004 14:46:47
 Re: Re: Plow Parts in reply to riverbend, 05-16-2004 11:38:45
I know I can get some of the parts at Deere, but am needing some rolling cutter parts that arn't available through Deere anymore. Also, one of the plows I'm working on is a roll-over, and I will be needing some lefthand parts also. Thank you for youe responces. Anymore help would be greatly appreciated. Don
Brian
05-16-2004 07:58:25
Good luck, you might try your local farm supply store. At least you have a deere where parts should be more plentiful. I've got a Case centennial plow, went to the dealer and the kid at the parts counter said the parts would be no problem..just bring in the numbers. Returned with numbers..different parts guy..nothing available..maybe a moldboard for $90 or so plus shipping-to their dealership!
I take it you've already tried the JD dealership??
