It's Hay Time!!!!!!!!!!!
Hay Dr
05-14-2004 05:41:03
Time to change those blades on the drum and disc mowers and lay the hay down.
Ron in AR
05-14-2004 16:35:35
 Re: It's Hay Time!!!!!!!!!!! in reply to Hay Dr, 05-14-2004 05:41:03
Just finished our first 25 acres last week. 100 more to go. Hope to do that this coming week. Got 165 4X4 900# bales off the first 25 and it looks like the rest will be as good. Starting out to be a good hay year! Good luck everyone!
bosshog in AR
05-15-2004 03:37:49
 Re: Re: It's Hay Time!!!!!!!!!!! in reply to Ron in AR, 05-14-2004 16:35:35
We are newbys to this so please be patient. My dad passed away in September and we have about 120 acres in set aside land, which we have to disk to keep the grass down. The 220AC that we have is the same one that we used when we farmed back in the 70's. It has been a good work horse but would like to give her a rest. We would like to put it in hay, but my husband and I are green horns at this. Even though I grew up on a farm where we grew wheat and beans, and had 20,000 layers, I never had any experience in hay. First I have to get the land disked and land plained which I am working on now.
What would be the best bailer to get. We have a 245 Massey and just bought a 6 foot bush hog. 600 Wind Special.Any suggestions would be much appreciated.
Also we would like to get in to bushhogging for other people. We have some idea of what others are charging but would also like some imput on what to charge? Thanks from two greenhorns.
paul
05-15-2004 08:33:43
 Re: Re: Re: It's Hay Time!!!!!!!!!!! in reply to bosshog in AR, 05-15-2004 03:37:49
A little confusing on all points.... ;)
Setaside: Can't hay this where _I_ live, where do you live & what govt are you working with (under)? They _want_ grass to grow on setaside, no tillage allowed, so just totally different....
A bush hog does not normally make a good hay cutter, as it grinds up the hay too much. Works for 10 acres if you modify it, but not for 120 acres.
What is your climate, do you get 5 cuttings of alfalfa or 1 cutting of grass hay, and which type of hay do you want?
Are you looking for small square bales, or large round bales? What type of hay? How do you plan to handle the bales?
For 3-5 cuttings of 120 acres, you are looking at almost a full-time job & a great deal of $$$ in machinery. For 1 cutting in a northern dry area, much much less machinery & time needed.
So much to figure out, huh? :)
--->Paul
Tom in TN
05-14-2004 08:19:30
Dr. Hay,
What are drum and disk mowers?! I still use an old Ford 501 sickle bar mower. I put new ledger plates on it and adjusted the sickle bar clearances this winter. I'm waiting for the rain to stop to see whether or not it works better this year than it did last.
Good haying,
Tom in TN
Hay Dr.
05-14-2004 15:31:16
 Re: Re: It's Hay Time!!!!!!!!!!! in reply to Tom in TN, 05-14-2004 08:19:30
Drum & Disc mowers will mow any type of hay in any conditions. Drum mowers start are $1,900 and up and disc mowers are $3,800 and up.
Casey in Ky
05-14-2004 16:01:40
 Re: Re: Re: It's Hay Time!!!!!!!!!!! in reply to Hay Dr., 05-14-2004 15:31:16
What's the cheapest, used thing you've got on the lot(besides just a plain sickle bar mower) that'll cut hay??
Hay Dr.
05-15-2004 05:54:15
 Re: Re: Re: Re: It's Hay Time!!!!!!!!!!! in reply to Casey in Ky, 05-14-2004 16:01:40
It changes every day because we are trading and selling. Usually we will have used drum & disc mowers from $800 and up. We have hayines from $700 and up but you will have to call to know what's in stock. 423-282-6969
Thats the least of my pro
05-14-2004 07:10:49
Rain, Rain go away..... ...
HD19
05-14-2004 06:19:23
hay just starting to grow here.
