Case VAC mounted plow
Jerry W
05-13-2004 20:37:57
Can anybody send me a picture of a 2 bottom Eagle hitch mounted Case VAC plow or direct me to where I may see one a picture of one.
I think I may have found one but have no way of identifying one. No visible markings that I could see but it was painted green and came from a farm where I bought a 1950 VAC with Eagle Hitch.
Thanks Jerry
wheat straw
05-14-2004 15:08:00
 Re: Case VAC mounted plow in reply to Jerry W, 05-13-2004 20:37:57
Jerry,
look it over good. there is probably an eagle on the globe someshere if it is case. Check on the end of the furrow wheel hub, the hub on the coulters if it has them. They were usualy cast in there somewhere on the plow. Also the pull bar where your lower draft links attach are different than most. they have a "bolt" threaded into the end of them instead of just a bar with a hole in it for your pin to go through. check the block where the coulter swivels and see if there is an eagle. Any cast piece is a place for possable "eagle sitting".
If he had a vac, good chance it's a E series plow.
Grab in if it is
Wheat Straw
Nicholaus Sowder
05-14-2004 11:35:50
Case painted their implements green back then.
Bret
05-14-2004 08:34:48
It's gonna look just like a regular cat 1 3pt rig. The Eagle hitch setup varies just a bit from standard dimensions. I don't have a photo, but my Eagle 2-12 fits a Ford 3 pt just fine. FAr better plows than ANYTHING Ford ever made. Just wish I could find new points.
