Shortening Kewanee 500 Elevator?
Kerwin
05-12-2004 11:17:25
Anyone have an idea if one could shorten a Kewanee 500 elevator (galvanized box type, hay/grain elevator)? They seem to be made up of unique end sections, with several standard sections in between.
Just wondering if a section could be taken out and the chain shortened, etc., to get a shorter elevator. I suppose there might be a problem with the undercarriage being too large.
Thanks for the help.
bryan g in mo
05-12-2004 17:17:41
 Re: Shortening Kewanee 500 Elevator? in reply to Kerwin, 05-12-2004 11:17:25
You don't live in MO do you, because I was just looking at one a couple of weeks ago, thinking the same thing about shortening it . The one I saw the carriage had a whole bunch of other holes to shorten it , so it looked like it would be pretty easy to do.
Scotty
05-12-2004 13:21:57
On some 50' - 60' models the tires are spaced several feet farther apart which probably does make for a bigger / longer frame to carry it!
MF
05-12-2004 12:20:35
I've done it with a StanHoist Hay and Grain, took an ~10 foot section off and reduced the chain length. It worked fine. The good part is you can put it back on if needed.
