477 NH Haybine Question???
Mike in KY
05-12-2004 07:04:57
I also just purchased a 477 Haybine. While checking everything out and getting it ready for the field, I couldn't find an oil level mark or plug on the side of the gearbox to check oil level. I didn't get a manual with the haybine and a label on the gearbox states, "don't overfill." Question: do you just take the top cover off the gearbox and check the level? If so, what would be the correct level for the oil.
Steve from New Holland
05-13-2004 18:53:36
 Re: 477 NH Haybine Question??? in reply to Mike in KY, 05-12-2004 07:04:57
Mike, I personaly take the cover off and fill the box approximately 1/3 full. However, the level plug I think is the bottom bearing carrier bolt on the outside of the gearbox. It is a bearing carrier with 2 bolts. Steve
