One more ? - slip clutch same as overrun clutch?..
t-leigh
05-12-2004 05:05:05
Do they come on any of the new models or is it another purchase item?
Thanks.
Robert in W. Mi
05-13-2004 10:47:56
 Re: One more ? - slip clutch same as overrun clutc in reply to t-leigh, 05-12-2004 05:05:05
New models of what????? ????? ??? Tractors? yes, some that don't have live power have a "built in" over run clutch.
Rotary cutter??? No, i don't know of one cutter that comes with an over run clutch.
Robert
Sid
05-12-2004 06:00:55
They are not the same. A slip clutch is part of the equipment being powered and is designed to slip if becomes overloaded an example would be on a rotary mower that hits heavy cutting the clutch woulkd slip to prevent possible damage to either the mower or possibly the tractor. A overiding clutch allow the rotory mower or whatever to keep on spinning without spinning the PTO on the tractor.
Loren
05-12-2004 17:51:00
 Re: Re: One more ? - slip clutch same as overrun c in reply to Sid, 05-12-2004 06:00:55
If you know what a sprag clutch is think of the overrun as operating as a sprag.Will pull the load but does not provide deceleration to the load.
lloyd in sc
05-14-2004 21:18:12
 Re: Re: Re: One more ? - slip clutch same as overr in reply to Loren, 05-12-2004 17:51:00
Does an over run clutch help protect pto system (hitting stump or rock) like a slip clutch?
