NH 469 roller tension???
Matthew
05-12-2004 04:38:19
Been adjusting my newly accuired 469 hay bine. Seens the the upper roller has no tension on it. I can turn the crank handles and when I lift up on the upper roll by hand it moves freely. Can it be that after almost 40yrs of the tension being at the same tension the tensioner is shot. Or maybe they are just rusted in that position and need to be set free. Anyone ever have the some problem?
Matthew
Farmer Tom
05-12-2004 06:38:06
 Re: NH 469 roller tension??? in reply to Matthew, 05-12-2004 04:38:19
My 469 was acting the same way. What I found was the previous owner(s) had apparently tightened up the roll tension setting screws so much that it caused the bellcrank fitting located just under the roller drive to break the cast bellcrank fitting (did so on both sides) thus allowing the top roller to just float because there was nothing to connect the torsion bar tension to the roller via the tension adjustment screws.
I haven't figured out a good/easy way to replace the bellcrank fittings as yet. Maybe Steve from NH has a suggestion on this. The bellcrank fittings were still available about a year ago from NH.
Matthew
05-13-2004 04:43:54
 Re: Re: NH 469 roller tension??? in reply to Farmer Tom, 05-12-2004 06:38:06
Farmer Tom,
Do you still use the hay bine with the top roll in a floating position? Question is, the weight of the top roller it's self have enough down pressure to still crack the stems well enough? Mine tension rod I think is just froze up and needs to be worked free. Really can't see anything really damaged or broke.
Yeah maybe steve from hew holland will have a quick fix for us.
Matthew
Farmer Tom
05-13-2004 06:05:30
 Re: Re: Re: NH 469 roller tension??? in reply to Matthew, 05-13-2004 04:43:54
Matthew - Yes, I have/do. Probably not the smartest thing to do, but for me it does work. However, I am not recommending it should be done this way. Yes, the weight of the upper roller does some amount of stem crushing, but not the best. I am running mostly grasses through it, so I don't seem to have much stem material to crush. I have the parts to fix it, I am just looking for a good idea on how to do it without tearing the whole side off as it were; there has to be a simple way to accomplish it.
