AC no till corn planter
Larry
05-11-2004 17:36:31
I have a AC 2 row no-till planter with model 70 planter units. The double disk openers on one unit have been stoppin up. One of the disks will turn free but the other has a drag on it. Is there a way to take these disks apart? Are there bearings in these that need lubricating? Thanks.
Nebraska Cowman
05-12-2004 04:47:07
 Re: AC no till corn planter in reply to Larry, 05-11-2004 17:36:31
just guessing but most openers are a sealed bearing. they are generaly riveted in the hub and can be replaced.
jhill
05-13-2004 12:26:34
 Re: Re: AC no till corn planter in reply to Nebraska Cowman, 05-12-2004 04:47:07
I have one of these also. The bearing holder is riveted to the disk. There is a removable cover and a bolt thru the bearing holding it on. There is a sealed bearing inside and it is probably bad. A frequent problem. You'll have to cut the rivets to get the bearings out. I use oval headed screws to reassemble.
