new holland knotters
jnewark
05-11-2004 05:21:12
Greetings I know someone out there has to have some information on the new holland knotters, My super 76 (or 68 I forget the number) hayliner bailer is not knotting on the left side, it ties a knot about every 10th bale, I thought possibly the knot was comming untied, but can't tell. if I stop and trip it manually after it has not picked up any hay for a bit it will tie the knot..any help would be appricated
jack
[email protected]
busted
05-12-2004 11:45:47
 Re: new holland knotters in reply to jnewark, 05-11-2004 05:21:12
sounds like the string may be coming out of the twine holder. If you do not have a manual get one soon they are worth their weight in gold . Are you baling very tight?
Dan
05-12-2004 07:22:35
Firts of all get an operator's manuel. It will take you through the proper adjustments and trouble shooting. It sounds like the twine is not being held properly in the twine discs. Tying when the twine is under pressure, hay going through, is much different from then there is no tension on it. Again best thing is to get a manuel. A baler is too complicated to operate and maintain without one.
