JD 567 baler / chains
J.P.
05-10-2004 11:23:18
My father recently purchased a used 567 round baler and needs a liittle help with some information. On the right hand side of the baler there is a pair of chains that drive the pick-up reel (mega-tooth if that matters); the owner's manual lists the procedure and specs. for tensioning the outer most chain, but falls short of giving specs. for tensioning the inner final drive chain. Can someone help with this procedure? We know that the spring pressure on the idler is adjusted on the outside chain by removing a link if necessary, but what about the final drive chain?
Shep Va
05-11-2004 08:15:09
 Re: JD 567 baler / chains in reply to J.P., 05-10-2004 11:23:18
We have a 567 as well, but have never messed with those chains you are talking about. I hate to say it but as new as that baler is you should really talk to the JD dealer and have them tell you what the tension should be. That is the latest and greatest from Deere and they should be able to tell you anything you need to know about it.
Great baler though, a big step up from our old 530.
Good luck
